solidgoldcaddy
- Joined
- Jun 13, 2007
- 20
ok so im new here and i probably will mess terms up, but here goes. my first boat we just bought is a 1990 forester 1800 gt, with an omc 4.3L cobra 4BBL. the guy we bought it from put a whole new engine in, did a good job. but he added an electric fuel pump. the pump has 2 wires and it was mounted directly to the block under the manifold. rubber and stainless gas lines. so heres the problem. the pump has a pressure saftey switch. and has a primer switch so you can prime the carb then fire it up. it fires up and runs a little cold blooded right away, but after a few minutes its fine. then we took it out and ran between 1000 and 4000 rpm and vary the speed cause we are new and just trying to get a feel for the thing. the first time we had it out, i did the above and after about 30-40 minutes of that, the boat slowly sputtered and died. would not restart. so i dumped some gas in the carb and that would fire, but once it was burned, would not restart. after about 15-20 minutes of waiting, it would restart and then run fine for about 30-40 minutes and then die again. same problem. it does it in the driveway and it does it in the water, yes i hooked up the water to the ears to run it out of the water and i have worked extensively on car engines, this isnt too far off from that. so i figured it was a fuel pump problem. so i relocated the pump in the side compartment and ran it like that in the driveway for a good 45 minutes, it still does it and the pump is hot even though it isnt near the engine heat or any other heat source. the vent tube is clear, the pickup tube is clear, the filters are clear and new and i cant figure it out. should i replace the fuel pump? is it too small and thats why its heating up??? how much psi should be running to the carb from the pump??? is it vapor lock? i have a few questions and am stumped. sorry if that was a long post about a 2 sentance problem, but i like to inform to the fullest. thanks in advance to you guys. ive read here for a while and its the best source for info. thanks again. chris
