tompowers85
- Joined
- Nov 28, 2004
- 125
I have a 1975 merc 850 with WMK-17 carbs on it. I have rebuilt both carbs cleaned everything. I tuned the floats to manual specs. If the engine is cold and not running i can prime the bulb and it will stay hard for along time. Once i put the motor in my test tank and fire it up after aboat 10 minutes the balb will drain and the engine will stall. When I attempt to prime the bulb again gas starts spraying from the vent on top of the carburator (top carb mostly). I have also rebuilt the fuel pump and checked the valves. I can not find any leaks in the fuel line. Please help it is driving me crazy!!!
