fuel pump 25r70e
monkey box
I have a 25r70e and i am looking for a fuel pump. My parts book calls for a 382875.
I have found several other numbers on e-bay that are cheaper and appear to be identical. They include omc numbers 397445, 397839, and 391667. Are these the same and will they work just the same.
James R
Re: fuel pump 25r70e
OMC had a nasty habit of changing the part numbers many times. If the new pump offer states that it will fit your motor then it will work. You can check with the seller easily enough.
kbait
Call tim's outboard with your model number. They likely have a good used one for cheap.
218-682-2331
