TriadSteeler
- Joined
- Oct 26, 2006
- 237
'74 Merc 500 4cyl two carb setup.
I am having the same issues as others with running the fuel lines dry.
Pumping the bulb springs the motor back to life. I have rebuilt the carbs and the fuel pump.
I'm thinking this is either a stuck float/needle or the fuel pump.
When I first connected everything up, I messed up and connected the fuel pump backwards. The motor obviously wouldn't start, but I cranked it over 5 times, about 5-6 seconds per try. Would that destroy the FP diapragm/check valves and/or anything in the carbs. I just want to eliminate the easy stuff (fuel pump) before I tear the front end back apart to get at the carbs.
