cheburashka
- Joined
- May 28, 2005
- 715
Just got the correct fuel pump for my '74 140 Mercruiser. I want to make sure I'm installing it correctly. It looks like the filter housing should point down toward the bottom of the boat, but if I do this, the flange is upside-down compared to the pump I removed. Does this make a difference?
Second problem--I wanted to run metal fuel line instead of rubber hose on the pressure side. The parts store only had brake line, but the clerk assured me it would work. I didn't think it would, and I found out I was right when I tried to install it. Since there's nothing for the flange to butt up against inside of the fitting on the float bowl, the line ends up fitting loosely into the housing, and it seems like it would leak. Is there a generic type of fuel line which can be used in this application, or do I need to get the original Mercruiser part?
One final thing--what's the basic routing of the fuel line as it comes out of the pump? Is there anywhere I can find a picture of this?
Thanks
Thanks
