Fuel Pump Leak,easy fix?
FAV453
I have 225 (1998)I don't know the proper names for the section of the fuel pump that is leaking. If you look at it the first section is the oil inlet (wires attached) is screwed with 4 or 5 screws this is fine. The next section, Fuel inlet (I guess?) is attached with 6 screws. This pump section is leaking oil (no gas) at the flange that is joined by the 6 screws. Could this need a gasket or do I need to get a full rebuild kit? To service this will the fuel pump need to be removed from the engine or could I just remove the 6 screws?
