Fuel pump leak???
pipes0000
I have a 1986 evinrude 40hp VRO,
When I pump the primer on the fuel line I get fuel leaking out of the rear of the fuel pump.
I thought it could be a gasket on the pump,but the pump is plastic and I am not sure if it is serviceable
Should I replace this or is it OK.Thanks :confused:
tashasdaddy
Re: Fuel pump leak???
sounds like the diaphram is bad. i would just go to a block mounted premix pump, here is the sierra replacement. http://www.iboats.com/Sierra_18_735...z.36857--**********.678176570--view_id.174141
Part Number: 0395713
Description: PUMP AY,FUEL
Pack Qty: 1
Dimensions: 3.50 x 2.25 x 2.25 (in)
Weight: 0.44 lbs
Equivalent Parts: 0398338,0432451,0433387,0438556
krogie
i believe the chief has it right , simple fix to get you back in the water .if you remove to filter housing screw during the install be careful lto line the gasket back up carfully or it will leak like a faucet.
pipes0000
So the Round housing with the slotted screw is the filter on it? Will I need to relocate my in line bowl style filter,,,also is there any wiring to customize or would this just plug in to existing harness.If you have a step by step link that you could post it would be great.Thanks
Any Idea of the mix ratio for this motor? 40:1 ?
