outboardkiwi
- Joined
- Aug 19, 2004
- 34
I am about to install a Navman fuel flow transducer to my boat powered by a Johnson 90HP 1989 J90TLCEM. The VRO was disconnected on this motor when I purchased it and has been replaced with a pulse type pump, which has lead me to question this pumps ability to supply suitable fuel flow/pressure when the supply line will be further restricted with the addition of the transducer and a fuel filter/water separator(as reqd by the installation manual) Currently the only filter installed is the mesh filter in the pump. Fuel tanks are twin 6Gal portables. I am looking at maybe installing a non-VRO fuel pump (the one at looks like the original VRO) to supply a higher pressure or do you think the pulse type currently fitted would be sufficient for the job. <br />Thanks in advance.
