tripnbubbles
- Joined
- Jul 14, 2011
- 5
I have a 2002 5.0 GL its a holley 500 2 barrel carbed engine. Im kinda confused not sure if this is correct or not. so here i go i had to rebuild my motor and have it in. so was just going over all my of my wiring and testing everything and got to my fuel pump relay..... and relay tested fine but when i was checking the wiring i would turn on the key and relay would not engage so then i bumpet the starter and it engaged but did not stay engaged i tested the volts from the alt. (green wire) at 2.6 volts and the wire from the starter (orange wire) was 12 volt at the bump of the key. My question is why would the relay not stay on???????? the only thing i can think of is that mabee (and i realy dont know) is that the green(alt) wire becomes activated wants motor is running. Please someone help me with this i do not want to even try to start this motor with all the $$$$ i have dumped into it with out everything being correct. Thanks to all that reply in advance.
