I'm replacing the fuel pump on my 87 3.0 mercruiser . Is any trick to it or does it just bolt on the block...ie... how does the arm fit in the block?
Thanks ...although I don't think the fuel pump in the illustration you sent in is the same as mine I'll check it when I get home. I don't remember seeing the push rod protruding outside the block.
