Re: fuel pump
welcome to the electric fuel pump world and boats.....lol. How often do you run your boat, or change your fuel. Usually what I see are people that run there boat 2 to 3 times a year and fill up maybe 2 times, meaning bad gas. Fuel has a shelf life of like 10 days. What I am getting at is old fuel leaves deposits in your fuel system, these deposits are usually dry and flakey when there is not any fuel present, add fuel, and the deposits get gummy, causing fuel system nightmares, ie fuel pumps, carbs, injectors sticking. Does the fuel pump get so hot that you cannot touch it? I have this problem with brand new boats still in the shrink wrap. merc was the worst, i don't know, mybe the pump they use.<br /><br />One cure that I like is using a fuel shut off at the fuel tank outlet, and run your fuel system dry when you are finished with your boat. Always use fuel stabilizer when you are not going to use your boat for a few weeks
