Fuel pump
sullyboy
Hello I am the new guy on the block and need much help:facepalm: First my Vro was causing problems so I changed over to a Regular fule pump #0438559 attached should be a diegram. when I received the part there was nothing to show me where the lines went. I can tell where the main line goes, but the other two notta! can anyone out there help:confused: There is pulse & a carb line I know that much. the motor is a 1990 Johnson out board.
Thanks
Joseph (Aka Sullyboy)
boobie
Re: Fule pump
Re: Fule pump
The small brass fitting is the pulse line. The other is the fuel out let. The black one is the fuel inlet.
sullyboy
Re: Fule pump
Re: Fule pump
Thank You;) this will help much. The reason I changed over to a reg/fule pump was as I woul throtle to 4500 rpms I would loose power the tac would stsrt to come down, pump the fuel line blub the eng would increase rpms so I hope this works once again thank you.
QC
Re: Fuel pump
Welcome aboard sullyboy. I fixed the first and last post to fuEl. Your point did get across, and it is not that bigga deal as you noted. It does help with future searches though. All good. We hope you enjoy it here and the info you find is helpful. Good luck!
sullyboy
Re: Fuel pump
I want to thank all the replys;) The only thing I am haveing trouble with is that when under a load the fuel filter seems it is restricting the fuel flow; remove the filter the boat runs ok? So thats where I am at. I'm waiting on my Seloc outboard repair manual to arrive.
sullyboy
Re: Fuel pump
I want to say "FORGIVE ME ON MY GNILLEPS" SOMETIMES ME BRAIN MOVES TO FASTERFTHAN ME SDNAH ARR:cool:
boobie
Re: Fuel pump
Did you try blowing through it ?? Have you got it installed correctly ??
daselbee
Re: Fuel pump
Just funnin' you buddy. Just funnin'.
Have you tried shop.evinrude.com to find the proper filter...
There is a white plastic inline filter on lots of engines....stock from Evinrude.....but I am not sure if yours had it.
