fuel pump
midnightrider1818
hey guys. have a 89 Larson dc 215. I need a fuel pump for it. has a v8 gm 305 with a 4bb on it. don't have old part off yet so I don't have any numbers yet. thinking a sierra brand or carter. does anybody have any part numbers for this
achris
More fish than mountain goat
Difficult without an engine serial number, but this should be what you have. #1 is the pump, and the number is on the right hand side.
Chris.........
kenny nunez
When you get the new pump double check that the in&out locations are “clocked” right.
To help with replacing the pump, remove the coil wire and while holding the push rod against the cam bump the engine around until you feel the rod retract, then loop some twine around the back of the rod long enough and tie off to hold tension that will keep the rod from slipping down. After the pump is almost against the block just pull the twine out and tighten it up.
a big glob of grease will hold the pushrod in place as well.
