1994 Mercury 40ELPTO
1. Hooking a clear line to the carb side of the fuel pump, after pumping gas up to the clear tubing it will slowly leak back into the fuel pump. Pump rebuild?
2. Hooking clear hose to gas line before the fuel pump, gas will drain back to tank. Is there supposed to be a check valve in the bulb?
Fuel pump had a kit put in last year and I took it apart looking for trash but didn't find any.
