ok, upon researching here on other posts, here is what I have.
symptom fuel gage reads less than zero.
what I've checked
5-6 volts to sender, this is a good thing, guage has power and is regulating proper voltage.
ground pink sender wire, guage pegs to full, this is a good thing, no broken wires, guage appears to be functional.
assumption based on above = bad sender.........
confusing part though, resistance across sender was about 160, where it likely should have been with what I had in the tank for gas.
Bottom line is, it must be a bad sender right?
thanks.
what I've checked
thanks.
