Re: fuel sending unit ?
Slammer, You should be able to buy a universal replacement which has an adjustable float assembly. As Vip says, open the access panel, remove the wiring, remove the screws and pull out the old unit. Now (according to the directions on the new unit) measure and cut the float assembly to size, install it and connect the wiring.
