The fuel gauge on my 1989 Searay 160BR is not working. I've traced it down the fuel sending unit. Specifically, the float on the rod will not float. I've removed the sending unit and moved it by hand and the gauge moves with it. I also put it in a bucket of water and it works fine. However, when in the fuel tank it sinks. I tied a string around the float, put it in the tank and it registered empty. When I pulled the string up the fuel gauge would move to full.
The unit is a Rochester 8341-70. The specs say the float is an epoxy coated cork. Does anyone know of a suitable float replacement?
