Re: fuel sep restriction??
The question asked was if two fuel filters will restrict fuel flow.
Will this impede engine operation?
Doubtful
Anything the fuel has to pass through will restrict flow, as in the check valve at the fuel tank outlet. Does this valve impede engine operation as in wide open throttle RPM?
No
The valve is sized to permit sufficient flow for maximum RPM as designed.
None the less, will more fuel flow volume result with the value removed?
Yes
