fuel separator before or after primer bulb?
rickdb1boat
Re: fuel separator before or after primer bulb?
Fuel tank, filter, bulb....
tashasdaddy
thanks rick. thats what i thought, this one is rigged wrong.
deejaycee_2000
the bulb needs to be in between the motor and the filter ... like rick said .... fuel tank, filter, then bulb ......
rickdb1boat
Yeah, I made that mistake when I first installed mine. It worked fine for a year, but I figured I better change it....
JC1933
Hi guy's
My boat has fuel tank bulb than separator,it has run this way since 1995.
Is there a reason I should change it?
Mark42
My setup is tank, bulb, fuel filter/separator. I see no issue with the sequence of the bulb and filter as long as they both are located prior to the motor.
Probably best to design the layout to suit the boats needs: With my tank in front, it was better to have the fuel bulb in reach of the helm for priming/starting. The water/fuel filter is in the aft where the 3 way switch is for attaching additional portable fuel tanks and easy access for maint/water draining.
I guess it is possable for some really neglected tanks to develope some crud that is is big enought to clog the ball valves in the bulb, but that would be the extreme.
JC1933
That's what I thought , should not make a difference.
Thanks Mark42.
