Fuel Shut Valve
seawings
Question… Fuel Shut Off Valve:<br /><br />Engine…Mercury 150 Saltwater / Carbureted <br /><br />I have heard of two schools of thought on engine shut down at the end of the day. This is on the Texas Gulf Coast where summer heat and humidity rule.<br /><br />One school suggests (requires installing and using a fuel shut off valve) starve the engine on the last shut down, leaving no fuel in the carburetor. <br /><br />The other school says just shut it down…note that this group uses fuel additives like STA-BIL.<br /><br />Any comments would be appreciated.
highaltitude
Re: Fuel Shut Valve
it depends on the usage of the boat. if you are storing the boat for a long period of time you need to either run the carbs out of fuel or empty them. the fuel will evaporate over a period of time-leaving the oil to sit in the carbs.
Barnacle_Bill
Re: Fuel Shut Valve
Use Sta-Bil. Running the motor with fuel unplugged does not completely empty the carbs. It does however empty the cylinders and leaves them without lube and protection.
achris
More fish than mountain goat
Re: Fuel Shut Valve
Seawings,<br /><br />Do not run oil injected engines dry. The reason is that as the fuel lines empty of petrol the fuel pump will fill them with oil, then the carbs get filled with oil. If you see someone at a ramp having difficulty starting an engine, then when is does start there's a huge cloud of smoke; that because he ran the engine dry the last time he used it.<br /><br />Another issue to consider with multi-carbed engines is that as one carb 'runs dry' and its cylinder(s) stop firing, they suck water in from the exhaust system, leaving the engine with a belly full of water on the last shutdown. Do you really want the steel cylinder walls to have water on them till you next use the boat?<br /><br />Chris.........
seawings
Re: Fuel Shut Valve
Thanks...I am still new at this and find I have more questions than answers!! Between the postings and the FAQ's I am learning...Thanks all
