Fuel solid and have fire won’t crank
Cory76044
OT 820216 2004 EL 25 hp Mercury. Out of nowhere wouldn’t crank on lake after running perfect. Noticed the pee hose had come loose on bottom and two days before notice no charge going to battery. Should I start with rectifier ?
Texasmark
Won't crank means the starter won't spin the engine? Battery voltage? Battery OK, jump across starting solenoid......red wire on starter backup the line to the switch. I use a pair of common plier handles...will spark. If it does solenoid bad. If not starter needs testing.
Cory76044
Hello thank you for the help. I’m sorry it turns over strong it just won’t start. I will test spark today. I have sprayed fuel in carb. Checked the fuses and all grounds and connections. I’ve had issues with idling at times perfect at times low and rough then back to perfect without making adjustments. I’m new to outboards so forgive me for ignorance in terminology.
Texasmark
When did you change the plugs last? What do they look like? What fuel did you spray in the carb.....fresh?
Cory76044
Changed plugs 2 weeks ago. Yes fresh fuel. Was on the water went to move after 20 min of fishing. Have had boat on water 4 days a week for few months.
flyingscott
Is this a tiller or remote model? Is this a Mercury or tohatsu built motor?
Cory76044
Had carb rebuilt last Feb of this year from a local shop. Bottom of rectifier was sitting in water when hose came loose.
Cory76044
I do not show this in my wiring diagram in my manual two yellow wires go to the stater one ground wire the other blue wire goes back into the remote wiring harness is it possible to check this I still have no spark stater test good
