That's not really a good idea. The more gas you have, the slower it goes bad. If you try to drain your fuel lines and carbs, you'll never get ALL of the gas out. The little bit that is left will go bad faster than if you just left them full. <br /><br />The main reason gas goes bad is because the octane goes down as it sits. If you leave it for a few months, it would be a good idea to top off your tank with premium. It takes at least a couple years for it to get as SoLittle explained, and when that happens, you'll certainly know it. Bottom line is, if your gas still smells like gas, then it's good to use. The octane may be lower, and thus, adding premium is a good idea.Originally posted by SoLittle:<br />if you get all of the fuel out of the motor, lines, etc.
None really, and if you want to use it for the winter, go right ahead. But doing it at every fillup is just silly...complete and total waste of time and money.Originally posted by dsmith84:<br />Even if gas last for a couple of years, assuming it does, what if any damage can occur by using a stabalizer?
