Alright I'm sure this has been beat to death but here's my situation.
Twin 140 OMC outboards 1990-1992 Era, both fed from the same 210 gallon fuel tank, both thru the same water separating fuel filter, through transom fitting, fuel primer bulb in each line outside the transom, line in smaller fuel fliter under the cowl, line in to the fuel pump.
I just installed the water separating fuel filter and chnged fuel hoses. After filling the filter element tried to pump up the bulbs to prime the system. It never felt like they adequately primed and pumped up like they should have. At one point I found and air leak upstream (tank side) of the primer bulbs. When I would squeeze either bulb I could hear air being sucked in at the one fitting. Tightened it and I think its solved. ( I didn't replace the primer bulbs, just the hoses, the primers are merc quicksilver bulbs that were on the boat when I bought it.)
Took the boat out for a shake down cruise, the port engine developed a fuel starvation issue while the starboard engine was fine, keep in mind they are both fed from the same source and the same water sep. filter and tank. Idled the boat down for a few minutes, throttled it back up and they both ran just fine at WOT for about 5 minutes. My brother then had the boat out a few min later and appparently it was having idle issues and he had difficulty keeping them running. Any ideas?
