fuel starvation
sailorden
Hi
My 50HP Merc 500 was running well & then after we had been running it hard for a while it started to have fuel starvation issues.
Now it will only run if i keep pumping the bulb and if i stop pumping is starts to fade and then stall.
I thought it was the fuel pump so I changed the diaphamm, gaskets and check valves, and also sprayed carb clearer into the carbs etc. But its still the same problem
Any ideas anyone?
Thanks
Den
Bumpus7
Re: fuel starvation
Hi
Any ideas anyone?
Thanks
Den
Replace your fuel filter.
sailorden
Re: fuel starvation
Hi
I didnt know I had one.
Where is that? I'll look that my manual now to see if i can find it
Thanks
Den
Bumpus7
Re: fuel starvation
Hi
Thanks
Den
On my Evinrude under the cover I have a small one.
Just follow your fuel line under the cover to the carburetors, and there should be one.
There might be a fuel filter between your tank and motor.
bumpus
sailorden
Re: fuel starvation
Hi
No i dont seem to have a fuel filter to change. Could it be that I have not mixed enough 2 stroke oil into the petrol could this cause this effect?
Regards
Sailorden
CharlieB
Re: fuel starvation
You may have air leaking into the fuel line between the primer bulb and the fuel pump.
A worn O-ring at a fuel connector can let the fuel pump SUCK AIR yet when you put pressure on it with the primer it will seal and not leak.
