I have a 4.3 liter OMC in an 18ft Sunbird. When first starting the engine will run and then stop. First though was that the fuel pump wasn't working so I replaced the relay that powers the fuel pump. Removed the fuel filter and filled with fuel and the engine ran great. Same thing happened a week later. Removed the fuel filter filled with fuel and the engine ran great until a week later. It seems that the relay will not allow the fuel pump to start until the engine has started. It almost seems as though the fuel pump its loosing its prime. Do I need to replace the fuel pump or should I remove the relay and wire direct to fuel pump so the it starts to pump as soon as ignition is turned on. Thank for the help in advance.
