Johnson110
- Joined
- Dec 31, 2003
- 640
hello, i am having a problem with start up, johnson 110 vro disconnent, motor rebuilt 2 yrs ago. first start-up motor runs for a while then dies out. replaced water seperater motor then ran fine all day, next day same thing motor starts then dies out prime bulb its soft motor runs smooth. i dissconect water seperator put end of hose into gas tank motor runs fine! i reconnect water filter then start motor its runs fine today! motor will not run with filter seperater at first start of day seems it needs that direct connect to tank at first then its fine all day, changed filter with new one yesterday! could fuel pump be weak? but once motor is primed with gas its like a clock! any insites as to what is the problem, thanks guys
