Hello everyone, I have a two year old Johnson 15 hp longshaft, used on my sailboat. I use it only to push the boat in and out of the harbor. Total hours probably do not exceed 25 at this time.<br />My problem is fuel starvation, which startd at the end of the season last year. <br />When I start the engine I use the primer bulb to develop a good pressure. Engine starts with one pull. It will idle for a few minutes and die. When I go to the primer bulb it is empty. Here is the confusing part, if I run it at full throttle it will run all day. As soon as I drop back to low idle, it will die within a minute or so.<br />I spoke with the store I bought it from, and the service manager indicated that the fuel pump is good, but has no idea what is happening.<br />Could I have a bad check valve in the primer bulb, or possibly a bad fuel connector letting air in?<br />Has anyone else had this problem.<br />Thanks
