airwarrior
- Joined
- Nov 29, 2005
- 61
73 Johnson 85 hp.
Ok rebuilt carbs, replaced all fuel lines on engine, checked and cleaned fuel filter screen and I am not getting any fuel out of the carbs into the engine. The plugs are bone dry. I had this same problem prior to pulling and rebuilding the carbs.
The carbs have gas (pulled drain screws quite a bit comes out) but I am losing pressure from somewhere. The tank, fitting, hose and bulb are new. The line coming out of the bulb (yes arrow is point the rigth direction) was existing, but I blew air through it and the filter is clean so I think it is debris free. I can pump the bulb up and it gets firm, and stays firm. If I tilt the bulb air the arrow point up I can hear a girgling sound, like it is draining back into the tank. The fitting on the end of the hose that attaches to the engine has some play, you can wiggle it but it doesnt leak fuel.
I am not sure if I am losing pressure, have a defective bulb, bad fitting etc.... Since I am working on this all by myself, it is a reach from the center console to the motor.... I wanted to see if I was getting any fire... I cant see the plugs so I gave a little shot of starting fluid, I mean a very little shot.... I know it isnt good to do that but one time for a test shouldnt hurt... I hit the ingition switch and it sounded like it wanted to start.
So I am wondering what I have going on here.... a leak in the fuel system somewhere and I am losing pressure or a blockage of some kind that lets me pump but then bleeds off.
Any ideas?
Any ideas?
