I have a Mercrusier 3.0 L with Alpha One Gen II outdrive that I am preparing to winterize. I have two questions regarding the fuel system:
1. How do you ensure the craborator bowls are drained and fogg the engine at the same time? My thought is to remove the fuel supply at the fuel filter while the engine is running and allow the fuel pump to run dry until the engine stalls, while trying to time spraying fogging oil just as the engine runs out of fuel.
2. I have read conflicting information regarding how to store the fuel tank for the winter; I have gasoline with Ethanol in my area. Should I fill the fuel tank and add stabilizer to prevent condensation or drain the tank and add stabilizer to any remaining fuel to limit contact with the Ethanol.
Thanks for any comments.
