I just returned from a long (160 mi) trip down the river to the C. Bay and back. Everything onboard works fine except all of a sudden the gas gauge always reads close to full. If I disconnect either of the 2 wires to the sending unit, the gauge goes to empty so I figure the gauge and the wiring to the tank is ok. Here's the thing...This boat (97 Chris Craft Sea Skiff 20) has a 64 gallon plastic tank. When I opened the access cover in the deck over the sender and looked in, With about 30 gallons in the tank I saw the gas tank top is concave as if as the gas is used the tank top collapses down??? IS THIS OK?? As the tank top surface goes down only in the middle and not near the corners. Rectangular tank about 4 or 5 feet long by 2 feet wide by I'm not sure how thick. After a fill-up the tank looks nice and square (top flat). It's like there's a vacuum created inside the tank as gas is consumed. I tried opening the filler cap and I heard air rushing into the tank but it did not re-expand until actually filling with gas. To make a long story short, Is this nornal? Not a hiccup from the engine. By the way, the gauge was working fine up until this week. Maybe ok and just a stuck float?? Or maybe the float/sender is getting mashed to bottom of tank as the top gets sucked down. There is a vent hose from tank up to filler hole but once cap is on the system seems sealed. ??? Sorry for the long questions and thanks to alll your help.
