What is reasonable size for belly tank capacity for a small boat? <br />I looked at the KVE site mentioned in another post and it has a vent(?) at the front of the tank. Maybe if you had a center console you could hide it and be 6 inches high, but a side console would require a bump and access plate or raising the whole deck. I was looking at the Moeller line. They have all the connections at one end. All models would require moving the floor supports out and raising the deck 2 inches which is easy since it has no deck yet. All the connections could be confined to the stern. These are 28,29,40 gallon units and I'm questioning my sanity about potentially buying the 40 as it would be no harder to install than the 28 or 29. My StarCraft 16' with its 60HP should use 6 gal/hr at WOT, and the plate says 85HP, 1500lb or 7x150lb of bodies. Most of the new boats seem to have ~23 gal(161lb) and the 40gal(280lb) doesn't seem unreasonable and I don't have to fill it all the time.
