Fuel tank fitting
Drivewayboater2
Question….. what should be used on the threads of this fitting.
In addition what is to be used on the fuel fill rubber line? I know about 2 hose clamps must be used on each end. Is there a sealant to be used? Any help would be appreciated.
Chris1956
The thread fittings are tapered. Just make 'em tight and it should be fine.
use 2 clamps pointing is different directions on the rubber fuel line. No sealant necessary.
