Re: Fuel Tank in motor well - any info out there?
Sort of like this one? See link below.
More than likely, Moeller makes them. If you don't see it here, Google Moeller and ask them.
http://www.iboats.com/14-Gallon-Fue...5080629--**********.616982682--view_id.686988
Thanks DJ, I did browse Moeller before but did not ask about a custom tank (thinking it would be big $$$)
The shape of those tanks is just not quite right. My motor well is like a trapezoid. smaller width in the front, wider width in the rear and (the Sun Tracker boat tanks) are a semi "V" shaped bottom, where I could use just a flat bottom if the width measurements and height would fit.
I would think someone has already created these to help better utilize the available space.
I want to convert the current tank mounting area (both sides of the motor) to usable deck space for snorkling gear, fish landing and such. My boat has the playpen totally against the deck rails so there is No "outside" deck space to hold anything
