Hey guys. Just bought a 91 Sunbird Stinger and discovered it has a leak in the gas tank. I have already checked hoses and sending unit gasket and everything looks good there so it must be the tank. The tank is made of fiberglass and there is no hatch to get to it so the floor must be cut open. From this point I think I have 3 options. Please chime in on them and let me know which would work out the best:<br /><br />1. Not sure if this is a valid option but is there anyway I can patch the leak internally without cutting the floor and removing the tank?<br /><br />2. Cut floor and pull fiberglass tank and repair by re-glassing the holes. Would I be better off to re-glass the entire tank or just patch the holes? Is there any special resin or epoxy that I must use since it's a fuel tank?<br /><br />3. Cut floor and replace existing fiberglass tank with a poly tank. This option may prove to be difficult if I cannot find a poly tank that is the correct dimensions.
