boat BW Outrage 1979<br />motor Johnson 1989 150hp<br /><br />I am only using 35 gallons of my 66 gallon tank. After fueling up I only use 35 gallons before I need to refuel. I think I may have a broken pickup, but the fuel tank doesn't have a port near by to check or to make a repair. Any ideas? <br />It has 3 port holes in the deck:<br />Center Stern (outlet elbow)<br />Center center (gauge)<br />Forward port (inlet/vent)<br /><br />Opening the stern port allows me access to the elbow only, and I unscrewed it (though I think it was welded) and just the elbow came off. I could see down the pick up tube. THe problem is I think I have a pin hole in the pick up tube around midway. when the tank is half full it looses suction and gives the appearance that the tank is emty. Fill up the tank and she's good to go. Should I be able to inspect the pick up tube? Do I need to drain the tank and add an access plate to the tank??????
