fuel tank replacement
Dbailey
I have a Skeeter bass boat. It has a single 24 gallon gas tank that faces horizontally behind the livewells. I need to replace the drains on the livewells and do not have access while gas tank is still in boat. If I am pulling the tank anyway, I would like to replace it with two smaller tanks on either side of the boat. This way the middle, where the drain lines are routed, will have clear access. Does anyone know where to purchase farily inexpensive gas tanks and how to hook two up to one fill line?? Will this work? Thanks for any info.<br />Dustin
