Fuel Tank Transportation Safety
Olde Merc
With the boating season not too far around the corner I have a question that has been bugging me about transporting my boat fuel tank. In the boat seasons previous to this, I have used a 1/2 ton to tow my 14' aluminium fishing with a 20hp outboard boat. When I went on fishing trips, I would toss all the equipment in the back of the truck including the fuel tank. I figured that is was safer to carry the tank in the back of the truck since it's in an open area, and it doesn't bounce around as much as the trailer. Plus, since the boat does not have a flat floor, I figured this would save the boat hull from damage and dents. <br /><br />This year I have a new tow vehicle which is a station wagon. I am worried that it may be unsafe to carry the fuel tank in the back of the wagon because the cargo area is shared with the passenger compartment. Even though the tank is sealed, I still worry about vapours or the possiblity of disastor if I ever got into a car accident. At the same time, I am worried if I keep the tank in the boat, it will damage the boat hull since it will just be on the thin aluminium hull and the trailer bouces around quite a bit on rough back roads.<br /><br />So what's the best way to carry my fuel tank when I am pulling the boat with the station wagon? Should I fabricate some sort of "fuel tank holder" that would be secure enough to keep the tank in the bouncy trailer and not damge the hull? Or am I being overly worried about carrying the tank inside the back of a wagon? <br /><br />Any is advice appreciated.
D
DJ
Guest
Re: Fuel Tank Transportation Safety
Olde Merc,<br /><br />Excellent question.<br /><br />None of the portable fuel tanks are truly sealed. If you put it in the wagon, you are going to smell it, BIG TIME.<br /><br />Build something in the boat. The trick is going to be a way to hold the tank down firmly. If it cannot move, it is much less likely to cause any damage.
roscoe
Place it as far to the front of the boat as possible to reduce bouncing.<br /><br />We have just put our tank on a small piece of plywood, in the back of the boat. Got some of the half inch wide high density weatherstripping foam and applied it to the sides of the tank where it would rub on the boat. Strap a rubber bungee around it to keep it from sliding.<br /><br />My grandfather just threw his tank on a piece of carpet and hauled asz down every logging road he could find for over 40 years. A couple scuffs on the boat and tank, but he didn't care. Its not gonna bounce out.
ZmOz
I've carried my 12 gallon tank in the back of my cherokee several times...as well as several 5 gallon gas cans. Never smells...probably a bit dangerous in an accident; however, the tanks are designed to go through alot.....
I've done all of the above. Even with a station wagon (jeep cherokee) :D :D <br />But I'd go with roscoes idea, put a piece of plywood under the tank in the front of the boat and strap it down.
Olde Merc
Thanks for the great responses! I think that I am going to build a platform out of plywood that the tank can sit on and that I can strap down in the boat. The boat is in pretty good shape and I'd like to keep it that way.
Solittle
Could you secure the tank on top of the wagon? I don't think I would try it if it is bigger than 6 gallon though.
rickdb1boat
Fill it up when you get to where your're goin'.
Olde Merc
Thanks for the input guys, but I still think I am going to build a platform and keep it in the boat. <br /><br />I don't want to put it on the roof rack since this will decrease my gas mileage, and I don't know how safe it would be there if I ever got into an accident. Also, since my motor is only 20hp, it takes quite some time to use up a full tank of fuel. I have never used a full tank (or even close) on one trip, so there is almost always fuel left in the tank.
