Re: fuel tank
Your tank should have 4 holes/ports in it. Two big ones - gauges sender and fuel fill. and two small ones - fuel line to engine (this one has the anti-siphon valve in it) and vent. Everything should be removable (line should not be "made to" the tank) from the tank - unless a PO has done some major rework, in which case you probably have bigger safety issues.
The four tank penetrations are not always grouped together (mine are all on one end, but spread accross the width), and not all manufacturers are kind enough to provide access plates where needed.
Whatever you do, remember this is not a lawnmower, it's a boat with a closed bilge - gas fumes/leaks = explosion.
