MH Hawker
- Joined
- Jul 13, 2011
- 5,516
Last year I had to replace both of my 6 gallon tanks, while on a vacation some crack head decided he needed them more than I did. It took a lot of looking to find 2 new tanks with out the new EPA venting stuff and of course the selection was very limited. I ended up going with Moeller tanks with the build in sight fuel gage. I do like the tanks their very heavy built and the sight gage works fine. However their rated to be 6.5 gallon tanks and on ever refill I am lucky if I can get 5 gallons in them, This is a problem because I mix my fuel in 6 gallon batches and why I have 2 tanks, I run a tank dry and switch tanks, I use bottles of per-measured oil, 16 oz to 6 gallons is 50 to 1.
I pulled one of the tanks off and brought it home to see what the deal is with them. First is the fuel pick up, its a rigid tube with no filter a full 1 inch off of the bottom of the tank and the way the tank is shaped the pick up is on the high end of the tank, The tank is sort of wedge shaped, the second problem is a raised section in the tank that creates a air void that stops you from adding a 1/2 gallon.
The mods will be to raise one end of the tank to eliminate the air void area and change the rigid pick up to a flexible pick up tube to the lowest area in the tank. I realize it was made that way to stop water from getting picked up by the motor but The marina has 4 separator filters on its fuel supply. I don't need a in tank filter because I use one in the fuel line any way.
I realize their portable tanks, but their mounted on the back and I fill at the marina, it kills my back to try to lift them on and off of the back of the boat. I have all ready done one tank so I will see if it cures the problem and I will take a few pictures later today.
