redneckpunk
- Joined
- Nov 19, 2008
- 130
Im currently rebuilding a '70s Starcraft 14ft that I bought dirt cheap because it was pretty thrashed and the motor didnt run. The motor that was on it was a '77 Johnson 35hp and the PO had a single 6 gallon tank stowed away. That motor however had zero compression so its an anchor at this point. I purchased a nice running '90 Evinrude 30hp to eventually put on the boat but im curious about everyones thoughts about the fuel usage of the motor and if 6 gallons will be enough for a day on the water fishing? I have thought about upsizing the tank but that adds another 40+ pounds and Im not sure it would fit under the splashwell. Ive never run this size motor so Im uncertain. I know on my 12ft I had a 15hp SeaKing and 6 was plenty, as it was also on my 16ft with a 15hp. But this boat is a little heavier and the twice the motor
Thanks in advance
~RNP
Thanks in advance
~RNP
