My 22' Mexican built panga, with a F75 TLR motor (2010) seems to run easy at 4000 rpm with a 17" pitch prop and tops out at 5200 @ 33mph.
WOT range is listed at 5000 to 6000.
I bought another prop to be used as a spare....a different manufacturer and with "cleaver" style trailing edges....3 blade.......whereas the 17" prop has rounded "ears" on the back side.
Just for grins, I put on the 15" to feel the difference.
Hole shot was great but to get at an "easy" cruising RPM, I had to advance the RPM's to 4500....and the top speed was down by a few MPH.
And....at 4000 RPM, it seemed to be lugging just a bit, compared to the 4500.
I am more concerned with fuel burn than top speed. I never bury the throttle and am quite comfortable with 4000/4500 cruise @ mid 20MPH speeds.
Seems to me that by advancing the throttle by 500 RPM, to achieve the same "easy" running speed and "listening" to the hum of the engine, the motor would use more fuel.
IE: why push the throttle another 500 RPM, to get what I can get at 4000 RPM?
Lots of chatter on here about lugging the motor and so-forth....however, with the motor spinning at 4000 RPM with the 17", seems to be the sweet spot vs a sweet spot with the 15" at 4500.
For reference.....the 17" prop is a Solas Amita aluminum 14 1/4" X 17" and the 15" is a Michigan Wheel "Match" at 14 1/2"....with a cleaver style back edge.
