Hello,
Havent been here in a year or so but its boating time again!
I don't have a fuel water separator on my 19' Center console but plan to add one this weekend. Few questions I have:
Do they also filter out junk and crud besides separating water? Reason I ask is right now I am running on a portable tank and running good. I want to try and go back to the main built in tank. The plan is to drain the gas and install separator. Not to sure of the condition of the main fuel line and if the tank has crud in it.
I don't want to go backwards now that boat is operating properly. I figure if there is a problem from the ball back the filter will take care of it not to contiminate the motor and carbs again. Real nervous about getting junk in the motor. Hoping separator and filters will prevent that.
When searching for a fuel/water separator I see that there are 1/4 and 3/8 inputs, I assume for a 115HP Mariner outboard I want to go with the the 3/8? Am I right on this?
Lastly, Where do I install the separator, I have the nipple coming out of side on boat where the ball connects to. Does it go there where it is visible? or does it go in the bilge hidden but harder to access? It is a stander 19' center console.
thanks in advance!
thanks in advance!
