I have a 1987 DT200 and yesturday it stalled and I noticed the fuel primer bulb collapsed and cut off the fuel to the engine. I just replaced the fuel filter which is type that looks like an oil filter (about 15 gallons ago). I think it is a mercruiser brand system. Do these filters absorb so much water that it cuts off the fuel supply eventually? I bypassed the filter and had no troubles. Also, is there a check valve in most fuel tanks? I thought something might have clogged the pick up, so I blew compressed air into the tank and I couldn't get any in. So I put a vacuum on it and it sucked gas out fine. Any ideas?
