Rich976usaf
- Joined
- May 9, 2007
- 61
Gentlemen, thanks for all the prevoius threads very helpfull!!
Ok Evinrude 1985 115hp vro. Just bought this motor over the winter cheep. Rebuild the lower unit seals cleaned bearings and water pump. Rebuilt the carbs. Changed solenoid gaskets (leaking). Here is the problem. Starts right up, first crank when its cold. Idles fine.
However I have to have the red solenoid valve about half way open to maintain RPM at idle. If i close the valve (clockwise) the engine REVS HIGH out of control. If i open the valve it dies out. I have disconected the lines going from primer to carbs (proper working, fuel when valve open). I am starting to think its the VRO??? The primer bulb does not get rock hard after 4-5 pumps, Havent seen any fuel going into carbs when i primer bulb it alot. I think there is a pin hole in the diaphram????
VRO pumps are expensive. Does this sound right to all you experts of the boating world. Any suggestions and help would greatly appreciated!!!! Please help. Tomorrow I am going to buy a new external tank and lines and re-plumb the vro to eliminate the possibility of leaks. I am also under the impression that there is no rebuild kit for this motor.
F-16 Crew Cheif Veteran.
