Fuel
Jrato14
This website has truly been a savior and it is amazing how knowledgeable everyone is. As you could tell from my other post I am kind of learning as I go with a used boat I bought last season. My latest problem is when I run my Volvo gxi 5.0 3869255 the engine starts right up then runs for 2-3 mins then I start to hear a loud pitch squeel and it shuts off but can be restarted without a problem. The high pressure fuel pump is hot and I believe it is where the noise is coming from. Should I just assume it needs to be replaced. As always thank you so much for any insight
Jrato14
I am sure I sound like a fool but do you mean the entire fuel pump assembly like the pumps and filter
cyclops222
Is that 1 of those crappy pumps with black paint SPRAYED INSIDE of the pump and filter elements ?
BRICH1260
Check and make sure the fuel cell cooling lines are flowing properly. They can get clogged which can result in pumps overheating.
ESGWheel
Jrato14,
Here is a link to a comprehensive post about these fuel pumps. It also has other links for getting the pumps repaired, etc.
Hope this helps.
