Ok, I've searched the net and can't find much help with how my trailer winch is supposed to operate. I'm used to the spring loaded kind where you have to use your thumb to pull on the ratchet/gear catch to release the spool so you can pull out rope/strap slack when loading the boat. Then you let go with your thumb and start cranking. "click, click, click..." Basically the winch is always locked unless you manually release the catch. This is nice incase you get tired of cranking or you need to adjust your grip or reposition the boat.
my new to me boat and trailer has a which similar to this one
http://www.fultonperformance.com/product/details.asp?ProdID=T1100Z0101&cat=7920
with a rocker like ratchet gear catch. I can't figure this one out. The rocker is either engaged (appearing to lock the spool with the tab pushed up) or dis-engaged (tab down and the catch pulled back from the spool). But there doesn't seem to be a position where I can set it to actually "ratchet" or engage with the "click, click, click..." If I let go, it just starts unwinding unless I manually fiddle with it and re-engage the catch. But then I can't crank until i disengage it again.
This is a used setup. Am I missing a spring somewhere? I found this part package which looks like it would fit my rig but It doesn't look like there are any more parts in this repair kit than what I already have.
Just looking for a little insight. It seams odd that I can't get it to "click" while i crank and seems like a safety issue. If my hand were to slip and lose grip on the crank, it could come spinning back at me.
...and yes, I know I need a new strap.
https://www.wholesalemarine.com/p/F...het+Repair+Kit+(For++1100+-+1500+Models).html
