fumes in boat
flips
135hp johnston 1975<br />Back again sorry .When i ran this motor at wot<br />it seems to have alot of fumes sometimes in boat.<br />checked tank seems fine. Read alot of pages in forums and done some checks. Hose at bot of carb looks fine but was not all the way home,motor has alot of oil on it mainly to botom section.Cowl did have lots of oil in it, have not done decarb yet as i want to see what revs are first, as we have now got tacho working.Will decarb after next run and see what diff is.Also noticed that air intake seems very oily.<br />does this mean reeds.<br />Notice these fumes after a run a good hour at 3/4 wot
Joe Reeves
Re: fumes in boat
I don't have the answer to your problem but wanted to insert a note that there is a difference between oil fumes, raw gasoline fumes, and exhaust fumes. You might want to let us know which.
Solittle
Re: fumes in boat
The oil around the carb intake and pan is unburned oil from the fuel and is quite normal especially with the recycle hose not properly seated.<br /><br />Two cycle motors and especially the older ones tend to be smelly. Lots of guys love the smell.<br /><br />I don't think the reeds come into play with the fumes at all. Same with the decarb but that is good to do once in a while anyway.
flips
Re: fumes in boat
Thank you Joe Reeves & So Little<br />for you assitance.I have only had this motor for 4 weeks still ironing out the bugs.<br />Joe sorry with the fumes, boy what a dill<br />trip up stream in morning no fumes.Return trip fumes..<br />My son had sore eyes when we stoped, washed his eyes and he was fine, did not think of this untill now. Wind was behind us when this happened on our return, exhaust fumes...<br />Never had this happen with my merc 80.<br />Hope the recycle hose played some part in this as well.<br />So Little <br />With all the fumes and seeing alot of oil i looked thur posts ,thinking that fuel was blowing<br />back out carbs which said could be reeds or rings<br />but motor runs fine. Just abit jumpy at present as last owner was very slack on maintance.<br />Will run it again this weekend and see what happens. Let you know how we go.<br />Thanks again
ED21
Re: fumes in boat
You think your fumes are bad, try running downwind w/ a british seagull motor running 24:1 gas mix & moving about 4 mph. The blue cloud just hangs over you.<br />If this is happening at speed, maybe the shape of the boat causes the exhaust to loop back into the boat. <br />If it's at low speed maybe a tune up would help. If your boat speed is less than a following breeze, their isn't much you can do to escape the exhaust from being blown back on you.
flips
Re: fumes in boat
HI too all<br />Ran boat today 5000 rpm 40-44 mph no fumes<br />at all it was great.Son loved it .<br />Ed that is really bad fumes, think you are right<br />about boat shape.We are now traveling faster due to bigger motor 50 hp bigger, had to keep my foot on front carpet to keep it in boat. I am going to fit shade cover as the heat here kills you. Do you think this might help with air flow
flips
Re: fumes in boat
Just a up date.<br />I think smoke could be from oil,just got new mini bike for son and ran same oil boy does it smoke alot.I know i should not use this oil in the bike but it was instresting.I use caltex outboard oil and they have change it ,might be the promblem
