funliner transom replace
fm50ford
I have an Aristocrat Funliner don't know the year. I was told that the transom is only half wood at the top and the bottom is fiberglass. Is this true? What is the best way to go about replacing it? Also I found that the stringers are fiberglass and it has a double hull. Is there anything between the hulls that would need replacing? If so How would I go about seperating the hulls?
Thanks for any help it is really appreciated.
Fred
SigSaurP229
Re: funliner transom replace
Welcome to Iboats.
The only way to know for sure is pictures.
I doubt if it is a "double hull"
The stringers lie between the floor and the hull and is usually filled with flotation foam. If the foam is waterlogged than it will need to be replaced. Basically if you have rot then you need to cut the floor out drill core samples of everything scoop out the waterlogged foam and replace it.
There are several threads here on restoring old fiberglass boats.
To test the transom drill a few core samples.
Woodonglass
You might want to post so inquiries here...Aristocraft Boats
These guys know everything there is to know about these boats!:joyous:
fm50ford
Thanks for the information. Sig according to brochures at Aristocraft sight there is a double hull with fiberglass stringers and air floatation between the 2 hulls. I will investigate more. Thanks alot.
