Puzzling question here guys...
When I had drained my lower gear unit, the first few seconds consisted of all water draining out of the lower screw. What was left was only a few ounces of gear oil, but the oil was still greenish black, as if no water immulsion had occured. I just hooked up a leak tester to the lower unit, and it held 15 psi perfectly, completely surprising me. Is it safe to chalk the problem up to a poorly seated fill screw? Or do I have to look further into this? The reason Im confused is that the oil that did drain out seemed very clean still.
