Fuse Block or Not?
Dadwith2boys
Hello, I don't think it matters, but I have a 72 V-156 Glastron, which is in need of wiring for everything but the motor.
1st question, should I use a fuse block for all electrics except the trolling motor?
2nd question, should I use a separate battery for all electronics except the motor and the trolling motor?
Thank you in advance for you help.
-Scott
Silvertip
Re: Fuse Block or Not?
Yes you should use a fuse block. Why put accessories on the trolling motor battery? it simply isn't necessary. Leave them on the start battery. A killer stereo or other very high current draw device should go to an auxiliary battery.
bkwapisz
Yeah I totally agree with Sivertip here. Use a fuseblock and everything will be done right, durable and fused, rather than a spaghetti rats nest. You'll be glad in the long run if you have an issue with a component and the wiring's easy to follow. Don't bother asking me how I know this. :redface:
